Is it hard to install heated mirrors on a truck that didn't come with them?
I installed the heated mirrors from a 2000 expedition on my 2002 supercrew. I am not sure about the wiring being in your truck but here is a option for you to think about. I went to a salvage yard and got a rear defrost switch from a 1988 ford taurus. This switch is a timed switch for 12 min if I remember correctly. I ran a wire from my power point to the switch with a fuse inline and a wire out to each mirror. There is a ground in the the door already if you have power mirrors that you can use. When I wanted the mirrors heated just hit the switch and it will turn itself off. I don't think I ever had to hit it 2 times to clean the mirrors.
