Rear Locking Diff Question?
Old 08-01-2009, 09:59 AM
Deano-FX4's Avatar
Originally Posted by K-9 SAR
...the Traction Control system will also help the open diff.
From the Owners Guide:
exactly.
Old 08-01-2009, 10:26 AM
Tbird69's Avatar
Originally Posted by broncobran68
No it is when traction is unequal that it is 1wd. Traction can be lost and spin both wheels remember.
Very rarely does an open diff spin both wheels. The power will be directed to the right rear 90% of the time. that's just how open diffs work.
Old 08-01-2009, 08:25 PM
broncobran68's Avatar
Yeah I know. I was just making a subtle reference to another thread. I was just nitpicking a nitpicky response.
I have been stuck plenty of times with open diffs. That is why I opted for the Fx4 over a platinum.
Old 08-03-2009, 07:12 AM
APT's Avatar
APT
APT is offline
Originally Posted by Deano-FX4
no its not power goes to both wheels equally until traction is lost.
Effectively, 1 wheel drive. While power can go to either rear wheel, it will go to the one with the least amount of traction when not equal. If one tire is on ice and the other on dry asphalt, the tire on asphalt will not spin in opposite direction as the one on ice.
That Wiki page looks like it was written by a high school student. I like this How Stuff Works. page better.
Old 08-03-2009, 08:54 AM
Deano-FX4's Avatar
effectively no its not a 1wd
from your link the first line "The open differential always applies the same amount of torque to each wheel"
Old 08-03-2009, 09:04 AM
kingfish51's Avatar
That is correct as far as it goes. You need to add, "Until there is any change in the amount of resistance on any wheel". Even putting your hand on the wheel will keep it from spinning. That is not much difference.
Old 08-03-2009, 09:09 AM
yetti96's Avatar
Until the traction on each tire is not the same. Then you become a one-wheel-peel, peg leg, 1wd, etc etc.
Old 08-03-2009, 09:21 AM
Deano-FX4's Avatar
so you all drive around with one wheel spinning on ice or snow, mud all the time? no you drive around on dry paved roads, so under normal driving conditions it is NOT a 1wd.
Old 08-03-2009, 09:36 AM
kingfish51's Avatar
Guaranteed, if you floor it and peel out on a paved road, you will have one wheel spinning, and only one wheel. You will leave only one tire mark.
Old 08-03-2009, 09:49 AM
Deano-FX4's Avatar
so what would happen if both wheels maintains the exact same traction?
Old 08-03-2009, 10:19 AM
kingfish51's Avatar
Next to impossible, as all it would take would be a slightly different grain in the roadway, or a little dirt, more weight on one side, etc.
The only way I have been able to get 2 streaks of rubber is with a LS. When I had open diffs, it was always one streak.
Old 08-03-2009, 10:35 AM
APT's Avatar
APT
APT is offline
As Kingfish said, there is no such thing as "same traction". Tires worn a little differently, a few more grains of dirt under one tire, different weight loading on each tire (driver, no passenger, etc. Yes, under most people's normal driving conditions, open diff is fine. but turning in the rain, and snow, ice, sand, or dirt conditions prove the effectiveness of the open differential.
Brake applied traction control can also be effective if designed and tuned well. It is not the same as LSD, but it can work very well for everything buy rock crawling.
Old 08-03-2009, 10:48 AM
Deano-FX4's Avatar
i never said it was the same as a ls diff, but you guys keep confusing situations with theory. but the principle theory is both wheels receive equal amount of torque. the situation is what causes one wheel spin and the other to do nothing.
anyways this topic is dead.
Old 08-03-2009, 07:09 PM
Tbird69's Avatar
Until the next thread crops up asking the exact same question.
Quick Reply: Rear Locking Diff Question?
