Incubus Brawn and Tire info only - no pics.
Ok - just got back from tire rack. Wheel I have is the following.
Incubus Brawn - 20x9 with 6.18 backspacing and 30mm offset.
Did a dry run with no tire and everybody agreed plenty of clearance on the suspension. HOWEVER - the spokes on the rim will ever so slightly rub on the calipers. It is such a slight rub that grinding off 1/32" from the seam on the rotor casting will take care of the problem.
Tire Rack in Torrance, CA did not charge for this test run.
So with the test fitting done it looks like 35x12.50x20 toyo MT's are a go with a 2.5" level kit. Just posting this info to help others looking at this same rim combo.
Am also looking to upgrade brake pads to stop the brake dust before mounting aftermarket rims. Will pass along the info and results at a later date.
If anybody has a make/part number for AAL's for the 09's would appreciate that and their opinions of the ride after install.
Good luck to everyone else working through their own demons on aftermarket tires/wheels/level kits.
Regardless I will still change out pads. Have you gone to ceramic pads? there was a post here that stated the 2010 now have ceramic pads.
