mpg keeps restarting
Are you hitting the Reset button accidentally? Hitting the reset is the only think that has ever reset my mpg.
I've noticed mine to reset like that twice now -
Each time, I had started the truck, backed it out of the barn, then shut it off right away - the next time I started it I noticed the mpg reset.
So in my circumstance, I figured that I shut the truck off before the computer completed its start up cycle or something.
I was kind of obsessive with my new mpg readout, and was resetting it manually at every fill-up.
Around 4K miles, I finally gave in, and just let it be - now mine did reset ~4800 miles by itself.
So, maybe it does reset itself after a certain amount of time......
Mine reset itself once, no idea why. It was just after a long trip, and poof, reset. Then it acted wonky for awhile, trying to decide my mpg over the next week or so. It finally stopped going way up or way down (at one time it said I was getting like 17MPG, if only!) and settled back into it's normal routine. Been averaging 15.4 MPG all the time now. Not sure why it acted up, it was fine for months and then went kablooey, just the one time right after a long drive down and then back home.
Maybe you have something there -
Mine just reset itself this week. I was on the way to work and opened the sunroof and rear window, looked at the dash and it switched from reading the average mpg to trip A. I switched it over to average and it had reset itself and was showing around 17/18 mpg. However, it didn't take it long to settle back to the regular 13.4 mpg.
