Looking for Pics of a Bakflip HD on a 6.5 bed
Hey guys, as the title says I am looking for pictures of a Bakflip HD on a 6.5 bed. I picked one up and I am trying to position it correctly over the bed. I am specifically looking for pictures that show:
1) The position of the side rail rubber strips on the plastic bed side caps
2) The position of the rear cover seal over the tailgate (how much of the tailgate plastic cap is covered by the seal?
3) The position of the front cover seal over the front of the bed (right under the rear window)
Any pictures or comments you guys could post would be greatly appreciated.
you replied in this post before, this guy took several pics of his HD cover, some are close-up:
https://www.f150online.com/forums/20...lled-pics.html
The rear seal extends about 3/4-inch onto the tailgate cap on my truck.
Digitalamish, did your cover come with a piece of rubber (about 1/2 inch high) that goes along the front of the bed between the 2 plastic side rail caps? Mine did but I'm not sure if I should put it closer to the front of back edege of the front bed rail and how well it will stick to my Line-X bedliner. Any chance you might be able to take some close-up pictures of the front/rear/and side rails?
Oh, also, I didn't install the drain hoses. I wanted to see how wet it would get inside without them. Instead, I just took a 'freezer bag' type sandwich bag and rubber banded it tightly around the downspouts. Ever since I moved the cover forward to cover most of the front of the bed lip, I get very little water insided the bed. Of course the winter will be the test for that.
