Oil Life - System Check
So I had my oil changed the other day at 3600 miles. The problem is when I run a system check it shows I still have 49% remaining on the oil life. How does this get reset? Or, should the computer know the oil was changed? Kinda like when you refuel, the miles to empty changes.
STANDARD MESSAGE CENTER (IF EQUIPPED)
To reset the oil monitoring system to 100% after each oil change
[approximately 7,500 miles (12,000 km) or six months] perform the
following:
1. Press and release the
SELECT/RESET stem to display OIL
LIFE = XXX% HOLD RESET =
NEW.
2. Press and hold the
SELECT/RESET stem for two
seconds and release. Oil life is set to
100% and “OIL LIFE SET TO 100%”
is displayed.
3. While “OIL LIFE SET TO 100%”
is displayed, if a lower oil life start value is desired, press and release the
RESET control to reduce the start value. Each press of the
SELECT/RESET stem reduces the value by 10 percent.
Note: Oil life start value of 100% equals 7,500 miles (12,000 km) or six
months. For example, setting oil life start value to 60% sets the oil life
start value to 4,500 miles (7,200 km) and 108 days.
OPTIONAL MESSAGE CENTER (IF EQUIPPED)
1. Press and release the SETUP
control to display “OIL LIFE XXX%
HOLD RESET = NEW”.
2. Press and hold the RESET
control for two seconds and release.
Oil life is set to 100% and “OIL LIFE
SET TO 100%” is displayed.
Note: To change oil life 100% miles value from 7,500 miles (12,000 km)
or six months to another value, proceed to Step 3.
3. Once “OIL LIFE SET TO XXX%” is displayed, release and press the
RESET control switch to change the Oil Life Start Value. Each release
and press will reduce the value by 10%.
following:
NEW.
is displayed.
HOLD RESET = NEW”.
