Bedliner Question
Bedliner Question
I will be putting a Line-X liner in my 09 FX4 and am considering taking the plastic and step pole off the tailgate. The shop said they can put a plate over the hole it will leave and it will give the bed a uniform look. Has anyone else done this that can show me pictures of how it will look?
Give some serious thought before getting your new truck sprayed. I regret having my brand new truck sprayed because the line-x dealer botched the job after two attempts. The good news is line-x is permanent. The bad news is that a botched job is also permanent.
I have the same tailgate. The line-x dealer removed the plastic cover & pole. He sprayed the edge of the tailgate & reinstalled the plastic cover & pole. This part of the job looked fine.
The first time it was sprayed they missed a large area on the side and the paint was showing through. When the bed bolts were torqued back to factory specs the Line-X bulged out from under the heads. The texture was wavy & inconsistent.
The next time, they cut out the bulged areas, sanded, primed & resprayed. This time the thickness varied significantly all over the bed. The texture was even more inconsistent and the bed bolts can not be tightened any more than 20 ft-lbs without damaging the line-x. A dealer that frequents this site thinks that the the mix was incorrect producing a soft coating.
The bed extender locks no longer work because of the spray build up from the two attempts.
Here is a link to a post with more specifics:
http://www.ford-trucks.com/forums/86...questions.html
