Tire Pressure
If the tires are OE, go with the pressure that is on the door.
Tires do not have the recommended pressure molded on the side. What they have is the maximum cold pressure the tire can handle and what weight it can handle at that pressure. Do not use the pressure on the tire as all you will do is wear the tire out much quicker.
If talking about aftermarket tires, then the answer is it depends. If you purchased the same load range tire with the same maximum pressure, use what was on the door, otherwise, you will have to figure out what to use.
