Need mirror / defroster wiring diagram
If you have an FX4 with the rear defrost it is plug and play. No wiring required.
04 XLT
I am a little confused "added the power heated mirrors", maybe you can clarify.
Your FX4 should have had this as standard equipment IIRC
I have an XLT that does not have the heated mirror function, but I would like to add it so I am very interested in what you come up with. I don't have the rear defrost option either.
Cheers
Cheers
04 XLT
Cheers
Cheers
Mine does not have heated mirrors or signals from the factory. From what I hear, they are all wired for it. I added the mirrors and the turn signals work, now Im just trying to figure out how to turn on the heated mirrors. According to TASCA, they SJB "Smart Junction Box" is the same on all of the trucks. I looked and the fuse is there for the heated mirrors. So Im assuming the relay is there also, although it is not something that is visible looking into the SJB. In theory, I should only have to change out the heater controls with the set with the mirror switch and Id be all set. The problem is I hate to pay over 200 dollars just to get that switch. I figured if I could get the wiring diagram I could just add my own switch (even one out of another car) to activate the heated mirrors.
The 09 FX4 comes with rear defrost unless you get the power sliding rear window. No defrost with that until the 2010 MY.
In the States, on an 09 FX4 the heated mirrors come as an option, as part of the lux package, or as part of the FX4 Plus package.
BTW, you've got a really nice truck boataddict.
Was thinking there were probably differences between the Canadian and USA trucks - mainly defrosting/de-icing options !
So 04XLT are you 100% that all trucks have the heat element behind their mirrors? If it's true that's great news because I would love to get them rigged up for cheap.
