console vs jump seat
My XLT crew came with a jump seat with the small console.
I saw the XLT, yesterday, with the full console (I think it's called the "flow through console"). I decided that I'd prefer this one, instead.
Has anyone done this change? If so, do you happen to know the part numbers and how difficult it was to perform? It doesn't look that tough.
I don't believe its a "flow through console" those are on the FX4 and up. The flow through consoles also have the shifter on them. The XLTs have Captain's Chairs and a column shifter. I have one of those. The 20 portion of your 40/20/40 seats should just unbolt and the console should bolt right back in. I've seen a few for sale on ebay. Hope this helps.
Tasca told me that the entire dash is different, too, but I'm not sure why. I'm going to look at the one on the dealer's lot and find out what the difference is. I might just change the console, however, and not the dash. I can't imagine there being something that I needed from it.
The dash shouldn't be different for an XLT with the console. Only on the ones with the actual Flow through could I see there being any difference since they have the floor shifter and it does indeed mount flush to dash. The console for models with a column shifter is a different animal entirely and doesnt go all the way to the dash; kind of just sits up in the middle of the cab and goes about 2/3 of the way to the dash. If you asked them for a flow through console that may be why they told you you would need to change out the dash
does anyone know if the 04-08 xlt console will fit an 09? i havent seen a good picture of the new trucks to compare em but if they're the same, you can find them pretty cheap. heres a gray one for $89
Here it is
https://www.f150online.com/forums/20...o-09-10-a.html
