performance airfilter
/me chuckles at an air filter giving you performance increases
On a serious note, I have heard that this one works pretty good:
http://k-mansparts.com/items/motorcr...883-detail.htm
I've heard the same thing.
I believe Donaldson makes a good product. They are a military and commercial service supplier. In general more air means more dirt. Often the air box and piping is the restriction, not the filter element. I rememebr on the early Lightnings the stock air box had a 2.5" hole in the fender that acted as a restrictor plate. I would stick with a Donaldson or AFE 5-7 layer type filter. Too much filter oil burns up MAF sensors.
ignorance is bliss
OK fine:
It's just that I don't really feel like blowing an extra $50 for 1-4 HP. 1% HP gain isn't really worth it IMO. Now K&N's may prove more beneficial in terms of filtering if you drive a lot in particular conditions, so I'm not speaking to that, just that if you're looking for performance increases, an air filter alone isn't where you should be looking. Even the complete intakes (discussed at length in other threads) aren't really worth it - you might get 10 HP from one of those, for $300+. I'm not saying that K&N's are BAD, as I've used them before in other vehicles, just that the performance increase is negligible for the cost.
2. What increase in horsepower should I expect from a K&N replacement filter?
K&N direct replacement filters which install into your vehicle's factory air box can provide an increase of between 1 and 4 horsepower. Results will vary depending on your vehicle, driving habits, load on the engine (towing for example), existing air system restriction, and other factors.
statikuz, if you're a tool, you must be a Craftsman.
