FX4 Max Tow Mirror Swap--Inverted
Old 12-20-2009, 09:43 PM
N8-126's Avatar
I know most people are swapping out their paddle mirrors for the tow mirrors, but I went the other way and now have a few questions. The tow mirrors were great, but had to be folded in to fit in my garage. I was hoping the 2010 was power fold so I could use them, but no go so my cousin and I traded--his 2005 KR paddles for my 2009 FX4 Tow Mirrors. We switched the pins 8 and 11 and everything worked great on the KR. But not quite on the 09 FX4.
--The passenger turn signal is not working, I think I need to add a ground at pin location #2, but can't figure out why driver side works fine.
--Is it possible to make the power fold option work using the factory setup. I plan to purchase the KR/Platinum control, but I read a post where soneone else tried and couldn't get it to work.
Thanks for your help, N8-126.
Old 12-21-2009, 05:56 PM
SSCULLY's Avatar
Do you have the memory option on the 2009 truck ?
Old 12-21-2009, 10:13 PM
N8-126's Avatar
No, my FX4 doesn't have memory. But my cousins KR did.
Old 12-22-2009, 11:02 AM
SSCULLY's Avatar
The memory on the '05 did nothing with the exterior mirrors.
The pin 8 & 11 swap is only valid on the 04-06 & 07-08 MY mirror swaps, the 09-10 mirror swap you have a few additional changes.
The 09 mirror head, pin 8 is a common ground to the heater, lamp and signal.
The 05 mirror pins 2, 9, 11 are all grounds that are spliced external to the mirror head, 2= turn signal ground 9=heater ground 11= puddle lamp ground.
The 05 side mirror on the 09:
You have the correct ground for illumination ( puddle lamp ) with pin 8 - 11 swap.
Pins #2 & #9 both need to be changed to ground ( don't just ground what is there, that is the autodim driver's side mirror control on your 09 )
This needs to be done on both the driver's and passenger's side mirror connectors.
At the moment you are using the autodim - for the ground on the signal, and if you would have tested it, the heater not work ( autodim mirror + signal ) on the driver's side, and the passenger side is hanging in the air for the signal and heater.
Cut the wires to pins #2 & 9, and change them to a ground ( can splice into the existing ground in the door ) on both sides, and it should work.
If the autodim mirror control takes off at night, the signal or heater on the driver's side might stop working.
Old 12-23-2009, 07:33 PM
N8-126's Avatar
You rock-that was exactly the information that I was looking for. I will make the changes after Christmas and post the results (and before & after pics)
Old 12-25-2009, 11:16 PM
d4studmuf1n's Avatar
how much difference in width is the tow mirror vs the regular mirror, i have to fold in my regular mirror to fit in the garage and i have a few inches to mess with and i want the tow mirror, does anyone know where i could find the dimentions, i have looked for like an hour and i cant get the mesurement...
Old 12-28-2009, 07:08 PM
N8-126's Avatar
I don't the width difference, I will measure them when I add the ground connections on Wednesday. All I know is that I had to pull in one of the towing mirrors to fit in the garage door, and now I have 2 or 3 inches to spare on both sides.
Old 01-01-2010, 11:12 AM
N8-126's Avatar
I measured the KR mirrors last night. They are about 97" wide-edge to edge. I don't have the towing mirrors but they literally touched both sides of my garage door when I tried to pull in. My garage is 9' (108") with a 1/2" trim piece on both sides so I would guess that the Towing Mirrors are about 107" wide.
D4studmuf1n--When folded in, I think the towing mirrors and paddle mirrors are the same width. The truck measures about 83.5" with the mirrors folded in.
Old 01-02-2010, 01:24 PM
N8-126's Avatar
I finished the wiring for my reverse mirror swap. Thanks to SSCULLY it was pretty easy.
To put 05 KR paddle mirrors on an 09 FX4 (replacing towing mirrors) you need to:
1) Purchase a 9 Position Female D-Sub Connector (part # 276-1428) from RadioShack (~$1.50). The female pins in this connector are a good match for the factory connector.
2) Make the mirror swap leaving the connector disconnected.
3) Use a needle from the back side of the connector (wire side) to release the latch on pins 8 and 11. Swap these pins so that 8 is in 11s spot and vice versa.
4) On the driver side pull out pin number 9 and protect it so that it can not make contact with anything (I wrapped mine with electrical tape). This is the autodim mirror + wire. Then insert a new pin (from RadioShack) into slot number 9 with a 6 inch piece of 20 AWG wire. Ground this wire to the mirror bolt. I will attach a photo later today.
5) On the passenger side place a ground wire/pin assembly in slot 9 and 2. Then ground both wires to one of the mirror bolts.
Old 01-02-2010, 01:29 PM
N8-126's Avatar
Old 06-02-2012, 10:27 AM
Hans Huele's Avatar
I am intersted in the reverse: I just imported my King Ranch 2009 to the Caribbean. The roads here are that small that I definitely want to change the towing mirrors into the smaller, regular ones. Would you be interested to sell your regular mirrors?
Quick Reply: FX4 Max Tow Mirror Swap--Inverted
