HID light problems
HID light problems
I just finished installing a HID kit. Everything works good until I start the truck. When the vehicle is not running they lows work just fine. It is when the truck is running that the low beams will not turn on. Anyone else have this problem? As for wiring I just plugged right back into the factory harness.
yeah if im thinking correctly if you turn on the lights while the truck is off you are getting the full powered low beams but if you are just turning the truck on in the daylight your getting the DRL's. the drls have to be disabled or else they will blow the hid's. also you will probably need a relay for them to work properly.
Having the harness that runs directly to the battery with relays may solve your problem. The DRL's run by giving low voltage to the high beam circuit. If you get the relay harness, the DRL's will only be a "trigger" and not the power source. Unfortunately, it will mean your xenon's will be on all of the time.
