2010 Lariat Screw - Can't find the override/led
Old 01-03-2010 | 04:50 PM
Ranman's Avatar
I just took delivery of a 2010 Lariat Screw and have the PowerCode Remote start with separate fob. I quickly noticed that a remotely started engine dies when a door is opened (annoying). i searched the forums and found the instructions on how to disable the MyKey so that the engine will continue running until the key is inserted into the ingntion and turned on. Also found the instructions to extend running time to 15 mins.
My problem is that step one is to locate the override button and led and for the life of me, I can't find either of them. I know to look under the dash of the drivers side, at the harnesses, around the hood pop cover plate, etc, but I am stumped. I've found them on previous 150's (2004 and 2007), but no luck on the 2010. Am I missing something?
Old 01-03-2010 | 07:03 PM
SteveVFX4's Avatar
my only suggestion is try to find the brain unit for the system under the driver's side of the dash and then follow the main harness off that and you should find them. I think they just tape those 2 things to the harness.
Old 01-03-2010 | 10:51 PM
kawasakieric's Avatar
I am also interested in locating them. Please post if and where you find them.
Thank you
Old 01-04-2010 | 05:00 PM
skidoos's Avatar
I have 2009 XLT They are hard to find mine was right under the dash if you follow the collum down under you will see the brain of of the harness you will fine the push button overide switch . I could not fine the LED but notice it reflecking on the collum bracket and thats how i did mine. Works great even shut the horn off at start .Good luck skidoos
Old 01-06-2010 | 12:08 AM
Ranman's Avatar
Update! I found the override button and LED. In my case they were tucked way up the plastic panel under the steering wheel. I decided to remove the panel (3 screws at the bottom and two pressure snaps at the top), and once it was off, I found the button and LED almost immediatly. I'm sure the placement is dependent on who installs the system, but this might be helpful for others in the future with a similar issue. Thanks to all who responded.
Old 01-06-2010 | 06:15 PM
pvagabond's Avatar
Can you tell me how to override the parking lites coming on everytime a door is opened or closed on the 2010 Lariat. Maybe if that can be accomplished we can get rid of that annoying ding dinging and tach hands sweeping back and forth when you nturn the key on.
