Traction control
Traction control
We are getting a good deal of snow in North Texas right now...
Driving to work this morning the roads weren't really slick unless you went out of your way to find the slick spots ... which I did.
Traction control worked great! Kicked in just as I would expect it to. Here's the deal though, on the way home this evening, the truck felt like it was holding back, almost as if the traction control didn't shut off... does that make sense?
My minimal understanding of traction control is it reduces the power to the drive wheels to stop them from spinning, I supose maybe even applying some braking... I have a limited slip diff. so I assume that locked and then the traction control kicked in... The little squigly tire tracks in the info center came on when it activated and immediately went off once traction was gained again, indicating that it had shut down...
I'm just wondering if I have a problem with the traction control not shutting off... anyone else experience this?
It sounds like some people are still stuck in the mindset that unless your tires are spinning you aren't getting anywhere. When in fact the opposite is true. Spinning wheels does not equal traction when it comes to snow/ice.
Agreed. I have no trouble driving in the snow/ice and I never turn the TC off.
The TC wasn't a problem... I only took advantage of the conditions to find out how it works or if it works...
My concern is my truck still felt sluggish after the TC had shut down. This is after the truck sat for several hours in a parking garage. On the way home it just felt like it was holding back... as if the TC hadn't completely shut off...
Unbelievabley, we got about 8 inches of snow, maybe more, yesterday. Maybe I'll take it out and run the TC through it's paces again...
We have been battling TC all winter long at our ranch in South Texas. The wet winter has created lots of mud. TC kills momentum when pulling a trailer thru the gooey spots. Losing momentum leads to stuck trucks when there is a heavy trailer hitched to the back.
OP, mine has not had an issue disengaging. I would think that if yours was still engaged the message center would tell you so.
I worked at various ski areas in college. Every morning and evening we would have "amateur hour". In total amazement we would sit and gawk at all the tourists spinning their wheels at high speed and going nowhere. Sometimes we would have to send an "advisor" over to inform them they need to stop spinning their wheels if they want to go anywhere.
I've driven in the snow and ice my whole life and the goal is to minimize wheel spin to maximize foreward progress. But it is still fun to watch those who think they need to spin their wheels at 50 mph!
On Thursday night we would have races to the top of the mountain. No wheel spinners ever won that race.
Personally, I'm totally loving the snow in DFW (I live in the Haslet area and we got 11").
I did notice, after traction control had set in, or if I stopped and the tires spun before gaining traction (slowly) that the truck was harder to put in to reverse or park afterwards. I don't know if one had anything to do with the other, but the shifter definately didn't slide back in to Rev or Park as easily as normal.
Seems to be working fine after I restarted the truck though, so who knows if it was related.
[QUOTE=Real;4087445]LMFAO!
On Thursday night we would have races to the top of the mountain. No wheel spinners ever won that race.[/QUOTE
Ur not getting what im saying son...
I didn't have a problem with shifting to reverse or park at any point. I just felt like something was holding the truck back... Almost like I left the emergency brake on or something. Yes, I checked that... Haha.
Oh well it's not often in this area that TC is needed...
No you don't need tire spin to give you momentum. It's the opposite. The faster your wheels are spinning in ratio to the speed the less grip you have. Why do you think spinning your wheels when pulling away is a bad thing. It's because you have less traction than when the wheels are not spinning. Thats why TC is a good thing for people who cant drive. It's designed for people who think they know how to drive but they don't.
