Inner-Fender Liner/Protection solution?
Hello all...
I ordered a 2010 FX4 F150...which was built in late January and now en route to the dealer. Scheduled to pick it up end of February.
Question... If I understand correctly, all 2009/2010 F150's do NOT have any inner fenders/liners to protect the engine from mud, grime, etc. (crazy that Ford would do that) Is this accurate? If so, does anyone know if there are any aftermarket solutions that anyone has tried and liked?
Thanks in advance.
Dean
Thanks in advance.
Dean
Thanks in advance.
Dean
Thanks in advance.
Dean
Probably more useful would be thin, galvinized panels stamped from sheet steel to fair out the bottom of the truck. Of course the open design is better for deep water and more advanced off-roading.
Well, you could simply get a piece of thick rubber and have it riveted onto the inner fenders to close the gap and allow you to bend it around the fender to keep the suspension travel. Lots of old muscle cars (corvettes, etc) used this method. Most of them have a cut or two in the material at the bottom to allow the full travel of the suspension and still cover the hole.
