Leveling Truck
Old 03-08-2010 | 05:28 PM
dirtyd09stx's Avatar
Originally Posted by RedFX2
I got ya spdracer! and just to clarify dirtyd, I'm not wanting to slam my truck with airbags, merely wanting to level the truck out as there is a lot of wheel well space going on with these 09/10's. I think dropping the rear 2" would be completely acceptable and not too "ghetto-ish". To each their own, you don't see me going onto the "lifted" threads and invoking the 15th commandment, now do you...
ok ok, before this gets out of hand, the level either way would look good, i went with a front spacer, but after words left me looking for rear blocks or an add a leaf to achive bring the back on line with the front. so no a drop schacle wont look bad just bake sure the replace ment wheels and tires fill the space 22" look good, and should complete the teenage drug dealer look nicely. lol im kidding i will be nice im sure
Old 03-09-2010 | 12:20 AM
spdracer23's Avatar
The drop shackles aren't too difficult to install. I had a set on my 07 and I installed them by myself. An extra set of hands would have been nice though. The part no. is the same for the 2009-2010 as the 04-08's so I assume the install would be pretty much the same. They come with a set of shims for the rear end to adjust the pinion angle and I installed those on my 07 as well, but i am not sure if they are required on the new trucks. I am still trying to decide if I want to put a set on my 2010 or not. The rear doesn't seem to sit as high on my 2010, or maybe it's just me.
What do you think?
Old 03-09-2010 | 12:33 AM
RedFX2's Avatar
^^ nice ride man. I can see a slight difference in the rear wheel well (say that fast 5x). the question is: is 2" the perfect reduction? I would hate to install those things and have it be too low or not lowered enough. do you happen to have any pics of your '07? might be a good reference point for me to see. and it's nice to know that all it would take is another buddy helping me out to install the shackles. should be pretty easy to find a teenage drug dealer around town to help me...
Old 03-09-2010 | 05:12 PM
MikeT, looks like Summit and Jegs has a set of the Ground Force 2" shackles for $112.99+shipping. Summit wanted $12 to ship them, not sure about Jegs. You have to go thru the ordering process to find out.
I'm also curious as to how difficult these would be to install by myself. Can't find any kind of install manual on their respective sites.
never done it my self but removal of the back axle is a fairly simple undertaking with the right tools, look at some of the add a leaf and replacing the rear blocks fourms that will give you an idea of the process and should get you moving in the right direction, best of luck. (the process is similar your jusr going down instead of up.)
Old 03-31-2010 | 05:22 PM
spdracer23's Avatar
Sorry took so long to reply. Been at work for two weeks and forgot my laptop charger at home. lol
This is my 07 before the shackles,
Here it is after the shackles.
Old 04-01-2010 | 02:32 PM
3valve's Avatar
2wd truck=Drop Shackles, short and fat smooth tread tires
4wd truck=Front spacer, Tall and wide mudders
Just my opinion. Both combinations make for a really sweet truck in my opinion.
I've had both.
Old 04-01-2010 | 04:22 PM
Lightningquick's Avatar
i remember when they were still 29.95 from godfathers customs about 12 years ago
Old 04-01-2010 | 05:44 PM
FlashmasterK's Avatar
Either raising or lowering with shackles/spacers is a very easy process.
I have raised my front with HBS 2.5" spacers and I am planning on putting in lift shackles this weekend with a buddy who has drop shackles on his. Same principle
So basically, I got 2.5" lift in the front and 1.5" in the back for about $120, and the truck should sit with an ever so slight rake
