Connect Phone with SYNC
Go to "phone" (i assume you have the nav and/or same buttons as I do) and connect manually and see if that does the trick.
I've gone back into the house to get something with the wife and kids in the running truck. Came back out and the phone disconnects as well. It' just a limitation of the blue-tooth range. I now just shut off the truck when I get out.
The phone also disconnected after 5 minutes. I was sitting in the truck after I had shut the truck off.
I found my old WM smartphone kept it's BT connectivity with Sync better than my Android phone can ever hope for. The WM phone consistently connected to the BT system without a hassle.
Now, I have to manually turn off and on the BT radio on the Android phone to make sure a BT connection is made.
