Heavy Haulers
9000lbs plus a trailer capable of towing 9000lbs will put you at 12000lbs total trailer weight easy. No way I'd want to ever tow that with an F-150.
Diesel and gas cost about the same currently, and in the past year they've been within 10-15 cents of each other, and the diesel will get better mileage... And if you compare the cost of 3000 mile 7 quart oil changes vs 5000 mile 15 quart oil changes, you're paying barely any more.
You're right about the total weight of the tractor and trailer. He'd have a hard time finding a trailer capable of hauling a 9k lb tractor that doesn't weigh more than 3k lbs. With a 9k lb tractor, he'd likely be pushing the limits of an F250 as well.
I'm not trying to knock the diesel, but routine maintenance *IS* more expensive. A Super Duty with a V-10 gasser is a very capable truck, its only downside is awful gas mileage. However, towing something THAT heavy with a F-150 5.4 is going to knock the mileage down into the single digits and the V-10 won't be much worse than that, if any worse. If you are dragging that thing to the mountains, even the V-10 is going to run out of breath, there you NEED a diesel or something else with a turbocharger or supercharger.
Oh I wasn't saying anything regarding the costs of ownership, just that the diesel guys can get pretty close to the 5.4L's mpg's when under the right circumstances. The cost of maintenance is much more expensive on the diesels, but you are paying for the enormous capability of the truck. I thought the F250's were rated to tow over 15K lbs?
Ahh, well I don't think I'd be comfortable towing 10K+ pounds on a bumper hitch. Either way I wasn't advocating Diesel vs V10, they're both capable engines. I just meant 5.4L versus the Diesel is a big difference. I wouldn't have imagined there was a difference in tow rating between the diesel and V10 anyway since the limiting factor really isn't the engine.
