Need advice on removing the tailgate emblem
Just picked up my new screw FX4 last week; it had navigation but not the backup cam. I bought the backup cam and harness, and plan to install it this weekend.
I thought I saw a thread that showed how to remove the tailgate emblem, but I can't seem to find it again. If anyone knows where it is I would appreciate the link.
Not sure about a link but I don't think they're that difficult - Everything I've read says they're stuck on with 3M double sided tape. Twist a length of fishing line to form a saw blade, slide it behind the badge and work it up and down to loosen the adhesive. Eventually it will work loose and you can pull it off. Beware there are 3 prongs on the back of the emblem that slide into holes in the tailgate for alignment purposes. Some say a heat gun can help to soften the adhesive.
