Question about BakFlip installation
***SOLVED*** The items that I thought were missing are actually pre-installed
Hey guys, my BakFlip arrived today and I was pretty excited to get it installed... however when I read over the instructions (yeah I actually used the instructions...) it says that 04 and up F 150s need shims for the clamps. I checked the box and no shims were included. I'm also missing the 2 Arm Stay Locks with Fastening *****.
Just curious to know from some ppl who have installed the BakFlip: do the 09 and up F 150s actually need the shims or not? The website link to verify the need for shims seems to be broken; it just takes you back to the home page.
I was hoping to get it installed this weekend.
Thanks, I went and checked. They are in fact installed already. Only problem I have now is that the driver side is not level so, when I put the top on the driver side is sitting a higher than the passenger side.
I'll have to take a look at the install in the morning when it's a bit warmer; maybe it's the way I installed the rails that's causing it.
Rail shimming
I'm having a problem with the driver's side rail not sitting straight up and down either. They swear its the source of my awful leakage and last I heard they were sending me rails with 1/8" shims instead of the normal 1/16" shims. I need to followup on the status though because its been almost a week since I heard from them and I don't know if they ever shipped them to me.
Leaks
I just put a extang maxseal on mine today, about $20 on ebay. Seems like it will keep out the water just fine. the only problem ive noticed is its harder to close the tailgate, that should work its way out as the seal sets itself in there. I also filled the end of the rail near the tailgate with some hotglue to stop it from leaking rearward into the tailgate if it was on a hill.
Leaks
I am surprised that you have a large leak with that seal. It appears to be the most robust of the three styles. I have the "wiper" style which I think they are currently using on the F1. To fix the leaks, I requested that the wiper seal be replaced with your style but never got an answer. Looks like the leak issue is the same regardless of seal style.
The best solution is to install rear drains onto the end of the rails. The drain lines can then be routed out the holes for the bed extender rather than dumping into the bed.
This was not possible on mine because I have the factory bed extender. I had to make some custom parts, but now have a solution that prevents water from draining from the rear of the rails into the bed. The water is now routed out of the bed & works with the factory bed extender. If you have a bed extender & would like more information, let me know.
