my white sand lariat with: harley heads/tails, stealth bulbs, roush grille valance
hey guys,
thanks again for all the positive feedback! i have a few more pictures of the truck without the front license plate (wish i could keep it off but it's not worth getting pulled over). I also included some pics of the lower roush grille/grille bracket (starting out i planned on making a "how to" but it got a little too involved for me to be taking pics of every step)....enjoy!
shot of lower valance without ugly license plate
close up of lower grille valance....
CORRECTION, measure 11 inches from center (total 22"), if you measure 12 inches from center you are going to have a hard time taking the grille in and out for adjustments when making the bracket
the piece of roush grille i used had a total of eight bars, i ended up painting the top 2 and lowest bar flat black upon final installation....USE MASKING TAPE TO COVER GRILLE DURING MOCK UP, or it'll get beat to h*ll by the time you are done with it! i used a dremel tool to cut it up....
used duct tape while mocking up the bracket...
inside shot of bracket
shot of bracket from oppsite, used all stanless nuts, bolt, washers, etc. and used loctite on everything....
looking down at metal bracket (made from 1/8" x 3/4" steel), took out the plastic screws that attach the rubber "water/puddle guard" to the bumper and replaced the plastic screws with stainless bolts, stop nuts, and sheet metal washers (slightly bent over the top of the washers so they wouldn't rub/cut into the rubber guard)....
that's the best i can do explaining what i did! good luck, Post on this thread if you have anymore questions ans i'll answer them the best i can!
thanks man, i still had them off of my old truck and figured i might as well save $1K and put the money towards aftermarket rims rather than paying for new stock 20's again....
I am kind of going for that look, I did a lot of truck shopping before getting this truck and was considering an '08 Limited, problem was they were all used and cost just a few thousand less than what i could get a new truck with the "D-Plan"....
Originally, I got 2 of the Roush grilles for my '07 from the "Roush Overstock" ebay store....I think I paid around $180 for both, now I see they want $135 each, they must not have a million of them like they used to and are comfortable sitting on them for the right price....The piece I used was just a left over from the same mod I did on my '07....you might try the classifieds on this forum, I'm sure there's others with a chopped up Roush grille sitting in their garage collecting dust! Good luck!
http://cgi.ebay.com/ebaymotors/ROUSH...Q5fAccessories
i used a dremel tool with a circular cutting disc to cut up the grille.....and i guess the other parts you need is the steel and the time, i made the bracket from scratch so you need to be able to fabricate! otherwise you could probably figure out something by drilling holes and using zip ties! i did my lower valance on my 07 with the zip tie to license plate method...just wanted to do something a little more permanent this time around!
