2010 foglight mod
I'm not sure exactly what the OP means, having the fogs on all the time - like DRL's? Because both my '04 and '09 can have the fog's on without the headlights on.; Just turn your parking lights on, then your fog's.
As an aside, the fog's on the '09's absolutely SUCK compared to the fogs on the '04's and '97's. I don't know what they did, but they are less than useless. The fog's on my 2004 were fantastic!
Well what i was refering to COmetFLash is to have the fog lights on when the high beams are on also.
Thanks StormTech i know the bambimod and did it as i stated on my 04, now i am wanting to do the same think to the 2010. but sounds like it isnt going to work.
but thanks to all that answered also.
Guess i could use another relay and run them from the high beam wire to excite the relay coil.
reguards
Mo
reguards
Mo
reguards
Mo
reguards
Mo
Hello!
Don't give up! Search really IS yer friend!
https://www.f150online.com/forums/20...od-2009-a.html
Refer to the last 2 posts in that thread. That should do it - it CAN be done.
Good luck
MGD v4.2
Has anyone tried adjusting the fogs?
Seems like they might be pointed down way too far.
