Has anyone put bigger tires on a 2010?
#61
im running a 2.5'' level kit in the front on my 09 with OE 18's and 35x12.5 mud terrains. havent had a single issue with rubbing as of yet and it been about 4 months. BUT, turning uphill around any corners where the traction may be less than desirable(even at less than 10 km/h) my traction control still goes off like its possessed. ive also taken it to the dealer and they've re-calibrated for 305's but it seems like we are all having issues with that damn traction control. what a pain let me tell ya, especially if you are hauling a trailer.
#62
I wrote an e-mail to FORD, but recieved no response. I ended up pulling the leveling kit out, selling my tires, and decided to patiently wait for someone to figure it out.
I figure by the time my warranty is finished and these low profile scorpions are worn out, I'll put it back in and have a way to fix the traction control issue.
FYI for the guy who has the leveling kit, but left the stock tires on it. You won't have a problem. It is when you add the bigger tires, that the computer gets screwed up. I ran mine with the leveling kit and stock tires for a week with no problems, other than the huge gap between my tires and the fender. Keep this thing alive until we get an answer. eventually someone will figure out how to make this set up work in the new trucks.
#63
#65
#66
Well, count me in as having his same issue.... Here's the post I made before I was pointed to this one https://www.f150online.com/forums/20...lp-needed.html
Dumb question, what happens if we just ignore the TC kicking in? Is it "bad" for the truck in some way?
#68
MTNEER, I'm sorry to hear that you've had all this trouble but you're not alone on this one. I've had this problem all along and thought it was my 325s. Granted they do rub on the upper control arms a little at full lock. I disabled the Traction Control this morning (pressed and held the button for five seconds) and drove it to work with no noises at the three usual spots that I hear it. I'll try it again this afternoon and let you know what I find.
Seems like I've read on one of these forums that a tuner can disable the TC with a custom tune.
#69
#70
#71
#72
It is always on, unless you shut it off manually. When you shut the truck off it resets and will be on again when you start the truck.
#73
It is on by default each time you start the truck. Pressing the button turns it off. You will see the swerving lines on the display by the odometer when it's off.
You can press the button for five seconds and that will disable Rollover Stability Control, Electronic Stability Control and the Traction Control System. Just tap the button and that only disables the TCS which is all I've done. Check page 283 of you owners manual.
#74
Alright guys thanks to you both for helping me understand it. I just got the truck two weeks ago and my 05 had none of this stuff. The book confused me because it lists it all for all models at the same time i wasnt sure 100% what it meant.
I plan on doing 2" A.S. on this truck with either 305 65 18's or 295 70 17's so im sure i'll need the knowledge for these issues down the road.
I just cant leave trucks stock, lol!
