Has anyone put bigger tires on a 2010?
Old 03-27-2010, 04:36 PM
MTNEER's Avatar
I just bought a 2010 Screw FX4, and I love it. I bought the AS 2" leveling kit, and then put on some BFG 285/65/20's. The problem is rubbing in turns, but I can't tell where. Without the vehicle in motion, there is no touching, but when I take a hard left at about 20 mph, I get a vibration. I am assuming this is the tire rubbing, and hoping it isn't anything else.
Has anyone done this setup on the 2009 and 2010's? If so, did you have rubbing, and where?
Thanks.
As soon as I get this fixed, and clean the truck, I throw some pics up for anyone contemplating the same setup. (The truck is dirty because I've been hauling tree limbs knocked down from the snowstorm over a month ago.)
Old 03-27-2010, 05:26 PM
Rochester's Avatar
Thanks.
Could be hitting the a-arms. Look for a tire mark on the arms.
Old 03-27-2010, 10:32 PM
Joe Styles's Avatar
Cool
this might solve your problem 2009 Ford F150 is Fabtech’s 2" Shock Spacer Kit.,
i have a 09 lariot and want to fill the gap in the wheel wheel with some 33's
http://www.truckaddons.com/Catalog/s...rd_spacer.html
Old 03-28-2010, 12:32 AM
Borv's Avatar
^^^He has a kit like that. That the AS 2" leveling kit.
OP: What wheels? Ford 20" for the FX4 or after-market?
Old 03-28-2010, 01:14 AM
savage02's Avatar
you sure its not the traction control kickin on?
Old 03-28-2010, 01:30 AM
ruffn-it's Avatar
i second the a arm, i can barely get a finger inbetween them while the wheel is turned. also look for black scuffs on the front lower valence and to the rear of the tire, inner fender well. you can put some masking tape in those areas to help show you.
Old 03-28-2010, 04:10 AM
freekyFX4's Avatar
Stock wheels or aftermarket wheels? The offset of the wheels makes a huge difference in what size tires will fit.
Old 03-28-2010, 09:26 AM
used2vtec's Avatar
Did you get the truck aligned after you installed the AS kit?
Old 03-28-2010, 10:17 AM
Reel Cajun's Avatar
I just replaced my tires with 305/55R20's on oe wheels and they fit well and look great. 2 1/2" leveling kit and AAL.
Old 03-28-2010, 10:50 AM
MTNEER's Avatar
It has the stock 20" rims, and the alignment was done after the work. Also, the thought on the traction control...It almost feels like that. It almost has a sound like abs brakes coming on. Is it possible that the tire size has screwed up the computer?
Old 03-28-2010, 10:51 AM
MTNEER's Avatar
And yes, I did get an alignment done after all the work was completed.
Old 03-28-2010, 10:52 AM
MTNEER's Avatar
BTW Freeky FX4...how 'bout them 'eers!
Old 03-28-2010, 02:23 PM
MTNEER's Avatar
So it is NOT RUBBING! Which is great! Unfortunately, it is the traction control kicking on. Any ideas on why, and if there is a solution other than turning it off.
Old 03-28-2010, 05:12 PM
freekyFX4's Avatar
Yes sir! They're looking good this year! Bob Huggins has whipped those guys into shape!
Old 03-28-2010, 06:53 PM
GS357's Avatar
Rel Cajun
Can we see pics of your new setup?
Quick Reply: Has anyone put bigger tires on a 2010?
