Mirror reflectors turned into turn signals how to w/pics
#271
Don't know why as they don't appear to be any different on the front side (didn't really do a side-by-side comparison, however), but it seems Ford made it this way to differentiate left versus right side reflectors to prevent incorrectly installing the wrong one.
#272
Augster,
I ended up with the same conclusion last night and then went forward with cutting the small plastic mirror housing section that separated the 2 prong tab on the reflector backing. Had to do this because it interfered with the end of the LED strip which has the shrink wrap for the wires.
#273
#274
I made the mistake of precuting the LED wires prior to removing the driver side reflector. Did this presuming it would be the same as the pass side where I dropped the wires from the straight side of the reflector because it lined up directly above the puddle hole. In the end there wasn't enough LED wire to drop it through the curved side and run it over to the puddle hole and out.
#276
I'm getting ready to do this mod on my Platinum Screw and just want to verify that it seems that everyone that did the mod through the underside of the mirror did NOT have the puddle light there. Please let me know if I'm incorrect in assuming that the presence of the puddle light dictates that you need to pull the mirrors of as the OP did. Thanks in advance for the help and I apologize if this was covered, I have gone through the thread a couple of time and have come to this conclusion, feel free to make me fell like I'm at home and tell me that I'm wrong !
#277
Even if you have the puddle light, it can be popped off (carefully) without removing the outer shell if you choose to do it the "hard" way.
Pulling off the mirror is very easy, however, be very careful if using a screwdriver to initially separate and pry between the mirror "slots" and mirror motor flange tab.
First step is to simply push the mirror all the way to one side (don't worry about the clicking sounds, but you could do this via the power control if you are squeamish on forcing it) to get access to one of two small, round tabs to use as leverage. For the driver's side, push in on the bottom to expose an opening through the top; for the passenger, do the opposite and push in on the inboard top to expose the bottom outboard:
You want to look for the round tab between the slot:
This photo shows the round tab without the mirror in place for clarification:
Use a flat blade screwdriver (no longer than 4" to prevent you doing what I did, which I will show at the end of these tips) to get between this small tab and mirror back:
Shot without the mirror to clarify where to place the flat tip screwdriver:
Then simply twist (rotate) the screwdriver to separate the tab away from the mirror in order for you to start working the flat blade screwdriver around the circumference of the round mirror motor flange to remove the mirror:
Removing the outer mirror shell and continuing with the mod should now be self explanatory, if not already described by previous posters.
After all is done and its time to finally reattach the mirror, simply line it up onto the round mounting flange and push in on the center of the mirror to snap into place. Make sure it's fully seated all round the flange.
NOW, regarding using the screwdriver indiscriminately... If you are going to use it pry around the mounting flange, do NOT push the tip past the end getting it behind the center of the mirror:
As you can see, the center back of the mirror is not really protected nor covered at all. If you somehow push the screwdriver into this delicate area and pry out, it will break the mirror thusly:
A $30 mistake on my part ; remedied with a new one from Tasca:
Good luck in your project!
#279
I just upgraded from an '09 XLT to an '11 FX2 with the puddle lamps. I was an early adopter and accidentally loosened the clips on the back of the mirror and needed to get a replacement. All told, the warranty paid for it but it *should* have cost me $245.78 according to the statement I got back from them. So I'd rather go in through the puddle lamp if possible.
So please, anyone doing the mod with puddle lamps, can you keep us informed if you do it through the lamp hole?
#280
I can understand if you are "gun shy" from your previous experience as there have been quite a few reports of mirror damage (and you can see, I wasn't immune to the "doh!" factor neither!).
There is a thread of those performing the mod through the puddle light opening, though some couldn't really get to the turn signal wires on one side as they were too short to pull out through the puddle lamp hole.
http://www.f150forum.com/f38/reflect...2-pics-101729/
I would be very careful when attempting to pry out the reflectors from the outside. Don't lever it against the mirror shell at all as the plastic is very soft and will deform easily. A suggestion proffered was to use a pick of some sort to disengage the small tab on the curved side of the reflector.
Good luck!
Good luck!
#281
This is my 2nd time doing this mod. First, on an '09 XLT the "long" way by pulling off the mirror. That method certainly offers a little extra space to work with but I was hoping to be a little quicker this time around and I didn't want to take any risks with my mirrors. I just bought a '11 FX2 Ecoboost and I decided to try going through the puddle lamp. Biggest obstacle was wiring in such a tight space - neither set of wires gave me enough slack to pull out of the mirror housing at all. I was able to complete the job in about an hour (taking pics and eating a couple tacos along the route).
I know its been documented a few times but I wanted to take a few pics in case the angle was helpful for other members. And, I wasn't sure if I had seen anyone do the mod with the puddle lamps.
Starting point:
Pull off puddle lamp (you can see the green and black wires I need just inside):
Pry off reflector:
Cut out reflector (I squared and cleaned this up after this pic):
Route wires and slide LEDs into place:
Re-install reflector:
Wire the lights up (I sealed up after splicing too):
Test:
All done:
Starting point:
Pry off reflector:
Test:
All done:
#282
#283
It was part of one of the packages I got. I think the FX Luxury package upgraded to the Power Fold mirrors and it included the puddle lamps.
#284
