Mirror reflectors turned into turn signals how to w/pics
Old 04-14-2010, 09:28 PM
bankrpt's Avatar
how did they turn out using the amber leds?
  #122
Old 04-14-2010, 09:47 PM
SFCFX4's Avatar
Can idiots wire this? I'd love to do this when I get some free time, but wiring anything scares the crap outta me. :o
  #123
Old 04-14-2010, 09:51 PM
bankrpt's Avatar
um yes you can wire it take the red wire from the led and tie it in with the green wire on the factory turn signal, and take black one and tie it to the black one
  #124
Old 04-14-2010, 09:55 PM
mnr602's Avatar
my first mod
Did this on my week old 2010 Platinum Screw. Absoultely the best mod I saw. Everything went off as instructed. Even got the exact same LEDS at autozone. Here are some observations I made (possibly already covered).
1. My drivers mirror had a thin silicone adhesive holding the mirrors on with the clips. Scared me when I heard the adhesive stretching away. None on the pass mirror...go figure?
2. I could not get the heating wires off the mirror to save my life. It was stretching the contacts, so I let it dangle the whole time.
3. The wire coming out of the led had a huge black shrinkwrap end, so I had to bevel the inside of the black mirror cover with the dremel to get the reflector to lay flat like original.
4. On a scale of mechanical ability I would consider myself an amateur with the dexteriry of a gorilla. So I was really scared prying the mirror off, but with a little patience and some really good lighting the whole project took me less than 2 hours. After doing one, I would easily get that down to an hour on a second install (now that I know what to expect)
Anyways, thanks again for this wonderful mod. The led selection was perfect the illumination they throw is easily three times as bright as the other mirror signal indicators. My F150 has the new ambient lighting so it fits the theme perfectly. Now I want to install something similiar under the entire 5.5' of bedrails that is triggered by the rear cargo light. Anyone done this or want to lead the way?
  #125
Old 04-14-2010, 09:56 PM
SFCFX4's Avatar
Cool, shouldn't be a problem then. When I get some time I'll give 'er a shot. I also have some leftover cans of night shade from a previous mod. I think I'll give the reflectors a few light hits for the heck of it.
  #126
Old 04-14-2010, 10:00 PM
bankrpt's Avatar
  #127
Old 04-15-2010, 12:33 PM
LBT's Avatar
LBT
LBT is offline
Here is a picture with the amber LEDs. I went with amber to take some of the edge off and make it more subtle. I have not personally seen one done in white but from the pictures there does not appear to be much difference.
  #128
Old 04-15-2010, 01:35 PM
ajaj's Avatar
Flimsy Wiring on Mirrors
I wrapped the glass with cardboard and used a piece of duct tape to fasten it to the top of the door panel.......wiring connectors looked hokey and didnt want to risk disconnecting them.
  #129
Old 04-18-2010, 04:20 PM
BlueF150XLT's Avatar
This is freakin sweet. I did it to my 2 week old f15o. I really think ford will pick this up. Too bad we could make some money on these. I have two 9 LED pieces I cut, just didn't solder any wires to them.
  #130
Old 04-18-2010, 09:40 PM
Platinum White's Avatar
Cool idea. I just purchased my first Ford F-150, 2010. I have been searching around for some mods I could do and this caught my eye. Took about 1.5 hrs, and turned out great. Thanks for the info... It is a different world driving a Ford, I have had 6 Dodge Diesels and decided to go gas burner. 1800 Miles and No regrets....
  #131
Old 04-20-2010, 02:59 PM
Roverandom's Avatar
The directions seem to indicate that you need a soldering gun to attach wires to the LED strip. Is this true? I don't have a soldering gun and would love to do this mod.
I actually thought these reflectors were turn signals like my wife has on her Acura TSX and I had on my 2008 Subaru Outback. Didn't realize they weren't until a couple of days after I bought the truck.
  #132
Old 04-20-2010, 05:32 PM
bankrpt's Avatar
No solder gun required just go to autozone and get some T-taps or just splice the wire and wire them up and tape them good
  #133
Old 04-23-2010, 12:30 PM
Roverandom's Avatar
Excellent! In that case, I may be doing this mod this weekend. Thanks for the info!
  #134
Old 04-24-2010, 04:22 PM
smkeater's Avatar
Check another one done. Finially had time yesterday to get it done. Autozone only had the amber LED's so I used those instead. Happy with the results, I will post a pic later
  #135
Old 04-27-2010, 12:58 PM
Nutty 5.0's Avatar
Another done here. Also they were out of white at Da Zone so went with Amber and work great. Also went with the 9 LED to find the entire reflector.
Quick Reply: Mirror reflectors turned into turn signals how to w/pics
