Another Factory TBC Install Question
I hooked up the factory TBC I ordered and took it to the dealership to have it programmed. They're telling me it is defective, but I wanted to check here before ordering another one.
I plugged it into the harness located behind the driver's side cubbie hole, and I installed the fuse and the circuit relay under the hood, but it shows no signs of getting power.
The information center hasn't shown any signs it's been connected and the buttons don't light up when the key is switched to the "On" position (according to the threads I've read on this site, that would support the dealership's conclusion).
Am I missing something? Also, what is the wiring harness under the steering column used for?
2010 F-150 SCrew 4x4 (Platinum)
I just recently installed the IBC in mine. I also have a '10 Platinum. It was a bit confusing at first, since the controller is different for the '09s and '10s. The controller for the '09s have a built in display while the one for the '10s has no readout. It just has the brake slider and buttons to add or remove brake power. It sends all messages thru the truck's info center. Also, I didn't have a harness attached to the back of the cubby. The one for the controller was located just under and to the right of the steering column on mine.
I hope it helps, and maybe someone else with more experience will chime in.
Regards,
Regards,
Thanks everyone for the replies. I do have the correct model. There is no display on it, just a "+", "-", and slider for controls. The + and - don't ever light up even though it's plugged in. I guess it's just a bad one. I'll post an update when I have time to get it swapped out.
I'm still curious about the harness mounted under the steering column. Is that for the service diagnostic/programming computer?
Thanks again!
Thanks again!
Thanks again!
Thanks again!
Let me know how it goes with the install and programming, I'm interested in doing this with mine. Does it matter if it's a 4x4 or 4x2?
I don't believe it matters as long as you have the factory tow package.
