2010 Dome Lights
Old 05-15-2010, 01:18 PM
2010FX2Sport's Avatar
2010 Dome Lights
I realy need some help in installing LED dome lights! I cant figure out how to take the plastic cover off to get to the bulb! I would like to take all the front and the back ones off. PLEASE HELP
Old 05-15-2010, 04:37 PM
tbraquet's Avatar
Welcome to the forum.
First if you open the sunglass holder next to the dome light you will the tabs to release the assy.
You should be able to pull down on the assy. and get it out. Pull the back part out and then you should be able to get the front part to pop out with a little effort.
Once it is out you can then unplug the wiring assy.
With the assy. out you can then release the tab holding the plastic cover. First release the tab on the rear part of the assy.
Then the tab on the front corner of the assy.
Then the tab on the front of the assy.
Do this on both sides of the assy. and the cover is removed and you can get to the lights.
On the rear dome light you just grab the front of the plastic lens and pull down and backwards and it should pop right off.
Old 05-15-2010, 08:58 PM
GS357's Avatar
Great instructions and pictures
Old 05-15-2010, 09:28 PM
MNOneFifty's Avatar
Where do you buy the replacement LEDs? It's so dark with the stock lights, something needs to be done.
Old 05-16-2010, 11:28 AM
thank you alot, realy helped, now does anyone know the sizes of the front and the back ones so i can order them on a website?
Old 05-16-2010, 11:29 AM
and a link or something
Old 05-16-2010, 04:59 PM
MarkY's Avatar
SEARCH for LED and dome light. There was a thread on here not long ago.
Old 05-16-2010, 05:37 PM
DarkShadowSTX's Avatar
Old 05-16-2010, 10:08 PM
Barnboy's Avatar
Here is another LED supplier
http://www.autolumination.com/
Old 05-16-2010, 11:48 PM
tbraquet's Avatar
Old 05-17-2010, 09:56 PM
thanks yall helped alot, is the dome light 42mm or 44mm?
Old 05-17-2010, 10:25 PM
44 is what I got for my 08 so it should work for your truck also
Old 05-23-2010, 03:13 PM
Is it the same as the 2010?
Old 05-23-2010, 05:28 PM
Should be the same but I'm not 100% sure. If I were you, I'd get the 44 because 2mm difference isn't much of a difference and I would rather have a bulb that should work for both applications whereas the 42mm will be too short if you need a 44mm. You can always measure your stock bulb to be positive, measure tip to tip.
Old 05-28-2010, 01:25 PM
Im not worried about using it for anything else, i just have to make sure its the right size
Quick Reply: 2010 Dome Lights
