Sync problems...
Mine loses it's connection about once a month or so. It usually just requires that I turn off the phone and then turn it back on and then next time the truck starts up it finds it. A couple of times I have had to take the battery out of the phone to reset it and then go through the steps to set up the sync relationship again.
I lose my connection if I leave my phone turned on in the truck when the truck is turned off. I lose connection if I haven't been in the truck for a couple days. I lose connection if the phone is in my pocket when I get in the truck. I lose connection if I don't turn the phone on until after I get in the truck. So in a word ...... yes!
I had the same problem about a month ago. Kept saying "No phone found" I tried to re-sync and got the same message. After an hour or so I was about to give up. But I didn't. I deleted my phone in Sync, turned off my phone for about five seconds, then re-sync my phone. Got it, gave me the number to put in my phone and all was golden. I did this while the engine was running.
I also have and HTC Incredible and have not had this problem. The only trouble I have had is if I forget to turn the Bluetooth on before I start the truck it doesn't always like to connect right away and I have to manually connect through the sync menu. But I have never had to relink it.
