phone?
Not sure how to check about privacy mode or hands free device. This is the first time we have tried the phone with sync or any truck/vehicle with sync.
Is there a setting or something that needs to be changed in the sync on the Ford? I have navigation, so has all sync settings through it. But, can't find anything about mic?
Assuming Sync responds to other commands, it sounds like your Sync module is bad.
Before you take it to the dealer, try removing the Sync fuse for 3-5 minutes. If that doesn't work, then try a master reset.
If neither of these work, you'll have to take it to the dealer.
I don't know of any Sync settings that would mute the microphone, other than HOLD. This would show up on the Phone screen.
Now that I think of it, make sure your phone isn't somehow automatically putting the call on hold.
I did uncheck "headset" under options and gonna see if that works.
bummer, I hate to have to take to dealer for this problem. Just got truck...
You could try contacting the Sync support center.
http://www.syncmyride.com/Own/Module...ContactUs.aspx
or http://www.syncmyride.com/Own/Module...ntactInfo.aspx
