Who else went from a F250 to F150?
#31
Correct, except in the chassis/cab configuration. I'm really talking about a used or leftover V-10, and I'd want a manual trans. Maybe the 6.2 will do a good job, but it still doesn't have the raw torque of the V-10. I'm certain that it will get a lot better gas mileage, the V-10 really sucks the fuel down. It pulls like a locomotive though. The only place where the diesel shows a major advantage is at high altitudes because of the turbo.
#32
Just this past weekend, we lost another 6.4. Rear end finally went out, headgasket had been leaking (loosing coolant for about a month), and one of the turbos were gone. It was an 09 model. Only had 90,000 or so on it
I guess that'll make it three new 6.7s.
I surely hope these are better than the old ones
#33
Use them, daily.
Wouldn't it be cheaper to fix the '09 than buy a new truck? Or are you just fed up with the 6.4 and want to get away from it at all cost?
#34
They're all farm trucks. They seldom go anywhere unless loaded with hay, cattle, equipment, etc, etc, etc. Frequently in the neighborhood of 20,000 net lbs (sshhhh, don't tell the DOT )
Every single truck I've had since the 6.0 has come out has been a royal PITA. Each truck has had major work done under warranty, from transmissions, to fuel pumps, to oil pumps, to cylinder heads, to turbos, to rear ends.
It has been a nightmare from the get-go and I/we are completely sick of them.
The 6.0s were definitely not worth saving, the 6.4s will have some useful life left for someone who doesn't depend on it as a TRUCK. If all they need to do is pull a boat or horse trailer one or twice a week, I'm sure they'd serve them well.
The repair costs are a drop in the bucket, being without the truck is much more costly.
I wish we still had the old 7.3s. The last one I got rid of had close to 700,000 miles. The only MAJOR repair was a rear end replaced once. I think the oil was changed a grand total of three times. :o
#35
