new truck wont turn over
just got off work last night after a hard day of the heat and put my key in ignition and the lights, air, radion came on but wouldnt start. the security light flickering and so i disconnected battery ground and reconnected and it is ok. i have 10000 miles on it and go outa town alot. Dont want this to happen again. Anyone have any ideas?
Arkguy29,
Do you have any kind of an auto starter or alarm system installed ?
with older fords.....02 mustang and my 05 fx4 if the alarm is activated you have to use the unlock buttons on the key fob to unlock the truck to restart the passive anti theft system....failure to do that will cause the vehicle to have everything working...but won't allow a start.
It's part of the anti theft system so someone cannot steal the truck. Try playing with your panic button on your key fob and then try starting the truck without deactivating and reactivating then deactivating the stock alarm system....
Should give you the same symptoms you experienced before you disconnected the battery.
Disconnection of the battery restarted the alarm system which allowed you to start under normal conditions.
The key is factory, thought maybe key became unprogrammed. used spare and didnt work. I got into my truck at lunch and the same freaking thing happened. tried to disconnect battery and still wouldnt work. so road side service came got it.
Ford reprogrammed truck. I picked it up started driving 2 hrs on a trip and all gauges in truck stopped working. Rpm, speedo, temp, air cond, the freaking dash looked like a xmas lights. so pissed. finally came back on. I made it where i was going, woke up the next morning and its been 2 days and havent had a problem yet. call ford. they are checking to see if anyone has had problems like this but they think instrument cluster is going out. i just want it fixed. anyone ever had problems like this.
Sounds like a battery. Somehow my truck fried a battery one day. I think I left the keys in the ingnition for like 4hrs or something and it literally fried the battery. Apparently the entire truck stays active with the keys in the ignition... so dont do that.
Ford will replace it no charge.
