Wheel Size question
Wheel Size question
I have a 2010 F150 XLT Scab 5.4L with 18" wheels. What issues would I have if I put 17" wheels and tires on? Any speedo, rearend or other issues or am I good to change out. I am looking at putting on 17" for the winter months. I can get a set of 17" wheels and winter tires for free from a friend who has a set from an 07.
Appreciate any input.
EDIT: Oops you're talking only about XLT sorry
Here is a super handy tire size calculator. You put in both tire sizes and it tells you all the differences between them in several categories including how much speedometer error you will see.
http://www.discounttire.com/dtcs/infoTireMath.dos
Really cool!
Really cool!
As I stated previously, it's not the rim diameter, but the amount of caliper clearance on the backside of the hub necessary to clear the wider calipers introduced on the 2010 models. From what I've seen your choices are the rims off a 2010 XLT or lower trim line or the Raptor.
