4X4 with 4" vs 4X2 with 6"
I have a 2010 Lariat 4X2 (only needed 4X2 for my needs, live in Hawaii so no bad weather, only thing I'm towing is my motorcycle) and wanted a 4" lift but there isn't one. I know the 4X4 sits up higher then the 4X2. Would a 4X4 with a Rancho 4" lift sit about the same height as a 4X2 with a Pro-Comp 6" lift? Both having 35's...
Thanks everyone for constructive answers.
the 4x4s only sit higher because they have different springs for wheel travel that is associated with off road situations. as such i imagine that even though ford makes probably a dozen different springs for the front and rear and the left and right sides respectively, a small manufactuerer who sources their springs from Eibach, Deaver or the steel mill down the street is only going to carry springs for the left and right sides in 1 rate and size. that said im confident in saying that the 6" lift will sit 2" higher than the 4" lift.
