2010 Platinum tires & spare
I don't think so. I have a 2009 FX4 that came with Pirelli Scorpion 20s. My spare is a Goodyear Wrangler LT275/65R18. Dimensionally this tire is the exact size as the 20s you have on your truck. I believe your truck is correct. The spare rarely matches the vehicle tires. This is, of course, just my experience.
That's normal for Platinum's. I believe it's also true if the truck has the optional 20" wheels (other then Platinum's).
Remember the only factor that is important with the spare is the overall diameter. If your stock tires have a OD of say 32", your spare should have that OD too. If the truck is a 4x4, and you're tires are a different OD then the spare. You can have issues running the spare, if you turn on 4 wheel drive. And if you have a 4x4 or 4x2 with a limited slip, you want to run the same OD sized tires on that axle or you can do damage.
