fast turn signal flashing
This is a link to the flasher that will correct you hyperflashing. http://shop.advanceautoparts.com/web...GRPLAMPAMS____I know it works on 04-08 F150s but not sure about 09+. FWIW, it worked on my 08.
Although , if it were so dang smart why TF doesn't it detect the presence of Leds and adjust the flash rate automagically
OP - As you might expect - this has been discussed before - and as y'all may also expect, SSCULLY was on the case, as usual
Everything you need to know is in here:
==>https://www.f150online.com/forums/el...er-relays.html
MGD
