new truck, now new trailer
Hey folks..
Since getting my 150 in June, we figured we needed something to pull .. so we just bought a Jayco Jay Flight 23'. New to travel trailers.
The truck is 5.4, 2wd w/3.55 limited slip, tow package.
The trailer reads 4480 lbs dry with a 525 lb hitch weight. GVR 6500 lbs.
Just checking.. the truck is more than adequate, yes ?
thanks
t
thanks
t
look in the brochure in the ford website which has the trailer ratings as per truck model. Here's what I did for my supercrew, 5.4 3.55 with tow; ie my formula to determine how heavy a trailer I can pull;
gcwr 15300, less truck weight ie 5500= 9800 trailer weight ( with no payload on truck) , then subtract the max payload 1750lbs assuming you max out the payload on your truck,= 8050 lbs left for a trailer load ( a conservative number (just the way I do it). Not sure about the hitch weight, which I thought was 500 lbs.
Sooo, you are fine. There are several examples in the owners guide also under towing.
Ferd
Ferd
Hey folks..
thanks
t
thanks
t
Hey folks..
The factory trailer brake controller is the best I've ever used and I highly recommend getting one installed. It works directly off the truck's braking system rather than being gyro/inertia activated so it seamlessly activates the trailer brakes with your brake pedal. Very smooth with no delay.
