got my lift in
I know you are thinking about going with the 37's but honestly before you do it think about it VERY hard. This is coming from someone who did a 6" lift with 37's and trust me. They say 37's will fit, and they do "fit" but once you start turning the wheel, turning and hitting small inclines, off roading and abruptly causing the front suspension to work you won't like what you have done. If you are going with only 6" you really, really should consider sticking with 35's.
*Note* I also had the Pro-Comp coils in the front and if you crank them you will gain about 1.5" or so max and your suspension will have no down travel what so ever. When I took out the 2" spacer and BDS struts I lost nearly a half inch in the front gonig to the pro comp coils. Not wanting to run the coils, with a spacer kit is what led me to sell off everything and go with the Rize lift. All of this due to being told 37's would "fit"
