Electronic locking differential question
The traction control does sort of act like a LS in that it may apply the brakes to the side that is slipping. However like LS, it can be defeated.
Diff Lockers are only ever intended for off roading. I would rather doubt that you would have problems getting up the hill in the rain towing a trailer, with all the weight on the rear wheels of the truck if your trailer is balanced correctly you should have plenty of traction. Traction control should kick in if you punch it too hard. TC works pretty well in these trucks IMO. No one would deny an LSD would be nice, but under load, a TC dependent system is probably more dependable.
I agree 100%. In all my past DD trucks I have bought them with the LS rear. I bought my new FX4 mainly for the 3.73 ratio,skid plates and paint to match bumpers. I am a spirited driver and the open rear drives me crazy! I'm sick of pulling around a corner trying to accelerate just to have the inside tire go up in smoke or sit and spin on a wet road. (Before the comments on TC I have disabled mine) I am researching the option of tossing my child grade, speed limited wannabe E-locker in the trash where it belongs and replacing it with a truetrac. If this is not an option I will be selling my fX4 and buying a new truck.
You can order the raptor control switch and the transfer case control module to solve this problem. You will be able to activate your locker in 2wd but I believe it will disengage around 12mph. Total cost of the parts will be around 150 and its rather easy to swap out the parts.
I beleive the person you are thinking of just tried the switch. You also need the t-case control module as well. There is a huge thread on this over on f150forum.com. I came across it over the weekend and learned alot of info.
Tim
Thats true but sometimes I really dont feel I should have to use 4x4. A couple examples would be when its snowing out and im trying to back my truck up my driveway. The open diff spins almost immediately, 4wd def gets the job done but if I could lock the rear wheels it would coast right on up. Same thing over at the boat launch. When coming up out of the water sometimes ill get a one wheelie peelie, again 4wd works but having an e-locker will solve this to. I know we bought 4wd for the exact examples I posted but I only like to use it as a last resort (when im stuck).
In my opinion.... Choose limited slip, unless you off road, my e-locker is useles. In east tn, not much snow, and def not enough to lock the rear end up. Unless stup pullin, or pullin a dozer, what uses? Never used mine, and one wheel spinning is what happens on 2 wd rangers!!! But if you want a fx4, sorry its an elocker, im going with xlt, with choices,
