fuel tank capacity
Old 10-14-2010, 02:12 AM
lilguy450's Avatar
fuel tank capacity
ok quick question about the fuel capacity of my truck i searched but i still cant find a definate answer i have a 2010 f150 STX screw 4x4 from what im reading its a 36 gallon tank but i filled up with 17 gallons today and it gave me 3/4 tank with 345 miles DTE. before i filled up i was halfway between empty and a quarter tank does this seem right for a 36 gallon tank? thanks for any input
Old 10-14-2010, 02:58 AM
blueovelboy's Avatar
niddle might be off a little but sounds like it might be close
Old 10-14-2010, 07:39 AM
wolfpack06's Avatar
Do you park on a hill or incline? I have a 36 gallon tank and my fuel gauge is always off. I've read and been told by the dealer that the larger tank/ fuel gauge have this problem if you park on an incline due to the baffling and where the pick up is. Unfortunately my driveway is pretty steep so I've learned to not rely on my gauge and what it says for how many miles I have left before empty, I just reset my trip odometer and go off the mileage driven for that tank.
Old 10-14-2010, 07:40 AM
L8 APEX's Avatar
The dealer should see it from the build sheet by the VIN. Most 2010 screws had the 36 gal tank. I get 450-500 miles on the DTE. I usually fill up a little below the 1/4 and it is 24-28 gallons. The tank is very long it takes up the whole frame. I will measure it for you. Mine is FX4 w tow 5.4 etc.
Sounds like you have the 26 or whatever the standard tank is with 345 DTE.
Old 10-14-2010, 11:16 AM
markinzeroland's Avatar
My 2010 F-150 brochure says that the 26 gallon tank is standard with 36 gallon having select availability on the XL/STX/XLT/LARIAT trim lines, and the 36 gallon standard on the FX4 trim line. Not sure what config is required to get the big tank on the XL/STX/XLT/LARIAT trim lines.
Old 10-14-2010, 11:33 AM
TX Chris's Avatar
Simple arithmetic on your numbers says you have the 26 gallon tank.
Old 10-14-2010, 11:44 AM
High-ster's Avatar
My Scab XLT 4x4 is 36 gallon.
Old 10-14-2010, 12:19 PM
lilguy450's Avatar
Thanks guys for the reply what's another way to figure this out besides filling it all the way up? I thought all 4x4 2010 f150s had 36 gallon tanks?
Old 10-14-2010, 12:44 PM
look at the window sticker it should be in the glove box. its law thay give it to you. you should have it in truck some where
Old 10-14-2010, 01:16 PM
TX Chris's Avatar
Dude. Simple math. Using the info you provided above, you have a 26 gallon tank. No question about it.
Now, if you're numbers were wrong, who knows.
Old 10-14-2010, 01:21 PM
L8 APEX's Avatar
Do you have 5.4 or towing?
345 mi DTE is 26gal along with 17gal fill at 1/4 tank.
My 36gal is 24 gal at 1/4 and 450-550 DTE. 36 is 18-20 gal at half tank.
Have the dealer run your VIN for the build sheet.
Old 10-14-2010, 02:13 PM
lilguy450's Avatar
im actually at the dealer right now getting an alarm put in im gonna ask about the gas tank but from what everyone is saying it makes sense that it is a 26 gallon although the tank is huge it goes from the driver seat all the way back to the rear axle im gonna take a look at some of the other f150s here oh and my needle is half way between half and 3/4 tank if that makes a difference...i didnt drive it at all after i filled up to when i got in it this morning and it does have a tow package with the 3.73 gearing and it has a 4.6 liter engine
thanks for all help
Old 10-14-2010, 04:31 PM
bluetoy's Avatar
Go here http://services.forddirect.fordvehic...icker.pdf?vin= add your vin to the end of the link. It will show your window sticker so you can see what tank you have.
Old 10-14-2010, 06:21 PM
cegan1825's Avatar
It is my understanding that 4x4s have the 36 gallon tank (with the exception of the Raptor and possibly the Harley). I'm confused on how you have a screw STX though. I could have swore STXs only come in regular cab or supercab...
Old 10-14-2010, 07:33 PM
SteveVFX4's Avatar
yeah, don't know how you can have a STX Screw, there is no such truck.
anyways, for 2010 all 4x4's have 36 gallon tanks except for Raptor and regular cab short bed 4x4's. The Harley is the only 4x2 truck to get a 36 gallon tank, all other 4x2's are 26 gallon. The official 2010 order guide (USA models) clearly spells this all out.
Quick Reply: fuel tank capacity
