Gas tanks: What are my options?
Old 11-24-2010, 09:18 AM
cucamelsmd15's Avatar
Our 2010 KR came with the 26gal tank (2WD). Since this is going to be a primary tow vehicle for my race car, Id like to consider either the upgrade to the 36gal tank from Ford, OR, an aftermarket tank in 36+ gallon capacity.
Ive been looking around on various sites, and I cant even find a part number for the 36 gallon tank from Ford. Assuming I could get one, is it a direct drop in on our SCREW 5.5' bed? Im also having a hard time finding a tank from an aftermarket supplier that will fit.
Thoughts?
Old 11-24-2010, 10:07 AM
IDIeselman's Avatar
https://www.f150online.com/forums/20...-capacity.html
I would not bother with aftermarket when you have the factory option available. Call your local dealer and talk with the parts dept, They will be able to tell you exactly what you need.
Old 11-24-2010, 07:10 PM
Ford12508's Avatar
A while back I looked at toolbox gas tanks. It looked exactly like a tool box for the bed, but it held gasoline and could be hooked up to the stock fuel tank to increase capacity greatly.
Old 12-01-2010, 11:35 AM
Called the local dealer, they cant find a part number for the 36 gal tank.
I tried looking on Tascas website, but they only go up to MY09. Any other suggestions?
Old 12-01-2010, 11:38 AM
Glen R's Avatar
Might try talking to the body shop at the dealer. They may have more insight.
Old 12-01-2010, 11:56 AM
Yeah, Ive got to take it on Friday to have the PCM flashed to recognize the trailer brake, so Ill probably do it then.
Old 12-01-2010, 01:51 PM
glc is online now
Was the 36 gallon tank even a factory option with the 5.5 bed?
Old 12-01-2010, 02:20 PM
I seem to recall seeing it on numerous 4x4 trucks.
Old 12-01-2010, 02:22 PM
tradosaurus's Avatar
How about carrying a 10 gallon gas can in the back of your truck?
Old 12-01-2010, 02:37 PM
Too many race car parts.
Old 12-01-2010, 07:35 PM
bmw4422's Avatar
mine has it, so it's doable.
Old 12-07-2010, 09:58 AM
Bump. Local shop couldnt find a PN before they raped me for $100 to flash the brake controller.
Old 12-07-2010, 10:08 AM
IDIeselman's Avatar
Next time you are at the dealer, Have a look under the FX4's and see just what would prevent you from using the large FX4 tank. It seems you would have more room under the 2WD being there is no transfer case or extra crossmember.
Old 12-07-2010, 11:44 AM
Glen R's Avatar
I found several listed at Silver states.
http://www.silverstatefordparts.com/...layCatalogid=0
Probably have to do a little research on capacities however.
Old 12-07-2010, 01:32 PM
CD1's Avatar
CD1
CD1 is offline
I got the 36 gallon tank as an option on my 2010 SCREW with the short bed.
Quick Reply: Gas tanks: What are my options?
