Brand New 2010 F150 xlt, 4.6L, OIL cahnge?
Old 12-14-2010, 01:04 PM
SSmike1's Avatar
Hi All,
I just got my new 2010 F-150, with the 4.6L V8 motor!!!!!
i drive hard, and use the "Remote Start" all the time in Wisconsin Cold.
I am thinking,...
1. i should change the oil every 4,000
2. i should use full synthetic?
3. can i use the Fram Oil Filter? PH2?
4. what is a M1 filter? Motorcraft
ADVICE PLEASE,
and what are the Numbers for these parts?
Motorcraft Oil filter = ?
WIX oil filter = ?
Fram oil filter = PH2?
thank you
Old 12-14-2010, 01:22 PM
gregsf150stx's Avatar
**D O N ' T** use a Fram Filter. they're crap!
I'd use a motorcraft.....dont know the entire model #, but I remember seeing FL-820S?
Originally Posted by SSmike1
Hi All,
I am thinking,...
ADVICE PLEASE,
WIX oil filter = ?
thank you
Old 12-14-2010, 02:46 PM
Blue07STX's Avatar
Motorcraft Synthetic Blend every 5K miles with a Motorcraft filter is what I've used since 2001 on my '01 F150, '02 Mustang GT and my '07 F150. The filter part number is in your owner's manual and it is most likely FL-820S.
I have found that Walmart is the best place to buy Motorcraft oil and oil filter.
Old 12-14-2010, 03:15 PM
Best way for quality and price
Old 12-14-2010, 10:21 PM
marshal's Avatar
i did my first oil change at 2K and went to Full Synthetic motocraft and a motocraft filter. changed it again at 12,000K miles to pennzoil full synthetic and a Wix filter. wix is the best
Old 12-14-2010, 10:35 PM
SSmike1's Avatar
GREAT, thank you for the advice.
YES, Motorcraft FL-802-S is the owners manual.
it says, either Synthetic Blend or Full Synthetic, and
5W-20 weight oil
Old 12-14-2010, 10:38 PM
SSmike1's Avatar
what is the wix # ?
and where did you buy it?
we have Advance Auto, Auto Zone, or NAPA, here in Wisconsin.
Old 12-14-2010, 10:45 PM
marshal's Avatar
part number is 51372
i got mine at o'reillys. they can be ordered off amazon too
Old 12-14-2010, 10:52 PM
glc is offline
The Wix is a good filter, but it's no better than the Motorcraft.
Old 12-15-2010, 06:16 PM
SSmike1's Avatar
thank you for all the help!
Old 12-15-2010, 06:44 PM
risupercrewman's Avatar
Stick with MotorCraft parts & you will be good!
Old 12-29-2010, 07:11 AM
scdoc's Avatar
NAPA filters are made by WIX, and you will spend less $$!
Old 12-29-2010, 10:31 AM
2stroked's Avatar
I'm surprised that nobody suggested that you have somebody else "enjoy" your first oil change - specifically the part where you remove the oil filter. Ford has virtually eliminated that dreaded "oil filter unscrews itself dumping oil all over the road" problem through the use of a space age epoxy. This epoxy holds the original oil filter in place and defies all conventional means of removal - including the frequent use of really bad words. The most common problem encountered when attempting to remove the original filter is the flipping over of the entire truck as the oil filter takes it around with it. Very embarrasing indeed.
Once that first filter is off though, you should be fine!
Old 12-29-2010, 05:57 PM
The gorilla from the factory is to blame!
Old 12-29-2010, 07:57 PM
SSmike1's Avatar
I did my first oil change, and the Orginal filter came off with NORMAL pressure, using a regular oil filter wrench.
i did not have any problems.
Quick Reply: Brand New 2010 F150 xlt, 4.6L, OIL cahnge?
