Wrench!
Old 12-15-2010 | 08:25 PM
HBfisherman's Avatar
Wrench!
Truck has 4k miles! At 2k the wrench popped up in the dash where the mileage is displayed. Drove to work, turned off the truck and turned it back on, and it didn't show again. Now this morning same thing, driving to work it turns on and I turn the truck off and its gone. What is it and what should I do?
Old 12-15-2010 | 08:55 PM
Green2005's Avatar
Take it back to the dealer...it is under warranty.
Old 12-15-2010 | 11:13 PM
bluegreenf150's Avatar
What? Only 4k miles? How is this possible?????? I thought 2010's are "proven".
Yep. Take it to the dealer and good luck. They'll get it fixed.
Old 12-15-2010 | 11:15 PM
The light is no longer on, is it something I should be worried about?
Old 12-15-2010 | 11:18 PM
jdtech65's Avatar
The light came on for a reason. Get the codes checked and that will give you an idea of what caused the light to come on.
Old 12-15-2010 | 11:23 PM
I wouldn't worry about it but I would take it in. And it will be documented should it happen again.
Old 12-15-2010 | 11:32 PM
cliff hanger's Avatar
Probably shouldn't happen again because the 2010s are "proven".
Old 12-16-2010 | 02:56 AM
ruffn-it's Avatar
Hey bluegreen, did I miss something? Its like the fourth time I've seen you post this on the 09+ forum. Im assuming your making a point to someone.
Old 02-19-2011 | 11:50 AM
5111's Avatar
Any resolution for this?
I had the same thing happen yesterday. I pulled over and turned the truck off. When I turned it back on it ran like there was nothing wrong. I drove it immediately to the dealership. They ran codes and found nothing so they then hooked it up to the diagnostic computer and ran it for 20 minutes and nothing. They said that they can't do anything unless they can duplicate the problem.
