Delayed 1-2 shift when manual shifting
Did Ford go soft on us? When I manually shift out of 1st gear, the engine slows down, and the shift comes in like a summer breeze, then the rpms kick back up.
Not liking this drive by wire stuff.
I know that 1st gear is geared really low, and 2nd might actually chirp if it would kick in like a normal trans. Maybe Ford programmed it to shift soft when manually shifted(?)
Will a tuner eliminate this problem, or am I asking for trans problems (or warranty concerns) by taking the sissy shift away?
Anybody have the same problem OR a cure?
Thanks,
SL
Thanks,
SL
What I loved about my 6R60 with my 4.6L 3 Valve in my 2008 Sport Trac was that it held the gear, and only that gear, when it was in 1 - 3 . With other vehicles, the gear selected is only the top gear, while it'll shift all gears up to that gear, or down from that gear.
The flip side was what your describing, it was a very slow engagement, not making it worth the hassle when accelerating. It was nice for a slow take off in slick stuff and engine braking when towing a trailer down hill.
I've heard they program the transmission that way to prevent damaging the transmission and the rearend. My understanding is when the transmission shift point happens between 1st to 2nd is also when the engine is in its 'sweet spot' of the torque band. If the line pressure is turned up, this could easily tear up the trans or rear. Imagine having a manual transmission, bringing the engine up to 5k rpm and dumping the clutch. This is very hard on the drivetrain. If you want the 2nd gear wheel chirp, I'd expect the transmission fail much sooner than expected, but I could be wrong here.
