calling all lifted 2009 and 2010 f150s
Old 01-22-2011, 05:49 PM
gomango05's Avatar
hey i bought a 6" bds suspension lift for my 2009 f150 and i was wondering what size backspacing will work with my kit. They say 5.5" backspacing with 37's. I'm running 35's. any pics and any help appreciated. I'm getting excited to get this put in, and the wife is tired of triping over the lift kit boxes stored in our spare bedroom!
Old 01-22-2011, 06:14 PM
ruffn-it's Avatar
I have a 6in bds, the specs are 18"x8.5" with 5 1/2" of backspacing (+20mm offset), they are tucked under the fenders real good.
But check out this thread too.
https://www.f150online.com/forums/20...latinum-2.html
Old 01-22-2011, 08:35 PM
SFssft1911's Avatar
As I understand it the maximum allowable backspacing is 5.5" regardless of the size of tire.
Old 01-22-2011, 08:55 PM
ruffn-it's Avatar
I'm not sure of what bds says, but its gotta be, any closer and my tires will be hitting the spindle, fingers barely fit between them.
Old 01-22-2011, 09:00 PM
gomango05's Avatar
do u guys think i'd beable to run a 4.52" backspacing?
Old 01-22-2011, 09:05 PM
Mwcarter41's Avatar
I have actually just purchased the 6in bds lift, 35's, with 20's. When I was searching for after market wheels, my installer said I needed between a 4in-5in backspace. No more than 5in. Personally, I'm not sure the difference but hope it helps in what your trying to figure out.
Old 01-22-2011, 09:09 PM
casedog's Avatar
Well it will definitely clear the inside (spindle). Now whether it clears the fender n bumper while turning depends on how wide that 4.52"backspaced wheel is. . If the wheel is 11" or narrower, ya should be fine.
Old 01-22-2011, 09:21 PM
casedog's Avatar
On the spindle side: This is the side that counts when talking the allowable offset. Tire size WILL matter as a 14.50tire on a 5.5" backspaced wheel will get you closer to the spindle than a 12.50 on that same wheel. Not even considering height of tire.. So basically, the WHEEL might not rub if it has 5.5" of backspacing but that backspacing may need to be different if you have wider meats hanging off of that wheel.
Old 01-22-2011, 09:44 PM
FX4life's Avatar
I guess your putting cranked coilovers in or a leveling kit on top of the 6" kit to fit 37's? I don't see it working any other way, Rize even had to do a bit of trimming to get 37's in on there truck for the 09-11 8" kit.
Old 01-22-2011, 09:59 PM
gomango05's Avatar
Mwcarter41, what wheel and tire combo did u go with? what back spacing?
Old 01-22-2011, 10:03 PM
casedog's Avatar
The Pro Comp 6" says it will fit 37s too. But Im like you, doubtful. I guess with a narrower wheel. I dunno. Will need to get closer to that 5.5 backspacing if u run 37s so the wheel n tire are tucked in the fenders more to avoid hitting the bumper/fenders... maybe, lol
Old 01-22-2011, 10:09 PM
Mwcarter41's Avatar
I went with the 20x10 Moto Metal 955 chrome and nitto trail grappler all terrains. If I remember correctly, the backspace in 5in. Installation is being completed next week. Will post pics when complete. I haven't seen this setup other than on internet so hoping it looks really good in person
Old 01-22-2011, 10:11 PM
ruffn-it's Avatar
Lol, 37x8.5in tires, that ought to work.
gomango05's Avatar
By the way u all have sweet looking trucks.I can't wait to get my done. I have my lift, now i'm just trying to decide on a tire and wheel combo. Its harder than i thought.
FX4life's Avatar
It may work with a 12.50 wide 37 and a super tucked in 9" wide wheel with some jacked up backspacing like you mentioned.. Then its on 'stilts' and looks awkward and disproportional. I find it odd that two 6" lift companies claim to fit 37's and Rize claims to easily clear 35's and clear 37's with trimming. Odd, I guess we will see how the OP's comes out..
Quick Reply: calling all lifted 2009 and 2010 f150s
