scab, passenger doors a little funky ?
Good day folks,
When I close the passenger main door there sounds to be sort of an internal rattle/thumb for lack of a better description. Never did it before, been happening for a month or 2 now.
If I close the doors independently of each other, or thump and knock them around I can't duplicate. Thumpety-thump on the interior door panel reveals nothing as well. When standing facing the doors, close the door, the sound almost seems to be coming from underneath at the cab corner ?? Nothing visibly loose etc. Weird.
Anyone have something similar to this go on ?
thanks either way.
thanks either way.
I am not sure what it is called, but I will call it the pressure relief port (lol).
Between the bed and the cab there is a flapper that allows for a pressure relief when you close the doors. If you close the rear driver's door and look down between the bed you will see it flap open and close. Not sure if that is the thump you are hearing.
