Flex Fuel anyone
Old 02-12-2011 | 01:01 AM
Fasteel's Avatar
Flex Fuel anyone
So is running this fuel with more Ethanol? My truck has only 2000 Kms on it so far. I think I'll try a tank of Flex next time I fill up. FS
Old 02-12-2011 | 02:02 AM
Expect to lose at least 3 miles per gallon.
Old 02-12-2011 | 03:13 AM
marshal's Avatar
ive been running E85 the last 8 tanks ive had in my truck just because im saving money by doing it. good results so far, though shady at 12mpg
Old 02-12-2011 | 09:26 AM
savage02's Avatar
E85 is 85% ethanol 15% gasoline compared with regular fuel which is usually 10% ethanol 90% gasoline. The E85 is cheaper at the pump but gets worse mpg's.
Old 02-12-2011 | 09:46 AM
jpetre's Avatar
Yes but not 30% cheaper, not worth it IMHO.
Old 02-12-2011 | 10:21 AM
Bomeyer15's Avatar
A big joke
Old 02-12-2011 | 11:04 AM
marshal's Avatar
it is around here, E85 is selling for 2.499 a gallon and regular unleaded is going for 3.159
Old 02-12-2011 | 11:17 AM
Power Kid's Avatar
It nees to be @ 66% price of Gas to get to "Equal".
And thats not taking into account the loss in range.
Good the the EB is not flex fuel, between that and the "small tank" you'd be stoping often!
And the 6.2... whats a 1/3 of range off 14 mpg even with the large tank?
Old 02-12-2011 | 01:26 PM
Each truck is going to be different as to how much mileage you will lose. Some people will save money, some won't.
Old 02-12-2011 | 02:40 PM
Blue07STX's Avatar
I would recommend running a tank of E10 every 4 or 5 tanks; just my thoughts. I think Ford recommends one tank of E10 or better at every oil change if all you run is E85 gas. It will be in your owner's manual.
Old 02-12-2011 | 04:00 PM
greencrew's Avatar
I didn't save enough on the cost of each gallon to cover the loss in MPG.
Old 02-12-2011 | 06:34 PM
junior's Avatar
How about half a tank of E85 and half a tank of E10 mixed? Would be E37.5 no?
Old 02-13-2011 | 12:26 PM
Fasteel's Avatar
gasoline types?
Just wondering if we have a mix called E 10 here in Canada? Thank you fellows for your reports on the ethanol blend, just the opposite of what the salesman that sold me my truck told me? FS
Old 02-13-2011 | 12:56 PM
Power Kid's Avatar
Some provinces have mandated ethanol (and biodiesel use) But it can be based on a 10% of total. So some may have 10% in fuel, some not. When combine dwith some gov't vehicles that use e85, as long as on the whole lot it = 10% they have met the guidelines.
Old 02-13-2011 | 05:12 PM
expy03's Avatar
If E85 were more available around here, I would try to figure out the proper mix for maximum torque increase. Ford shows a 25 lbs of torque increase with E85. Would be nice for towing in the hills.
