LED highbeam in dual beam projector set up?
back when i had projectors on my truck i made it so that my high beams didnt shut off my hid low beams, but with hid lows and halogen highs, high beams were no brighter....now if you had hid in both low and high that would be nice, nice cut off for your lows then with high beams it will glare everywhere and will be like day light
I currently have no need to run a high beam, but i've been wanting to just wire another low beam using the power from the alternate headlight and wire it to a switch inside to initially have all 4 lights on at the same time. Just need some extra hours in the day.
Yes...you can get your projectors to stay on even with the highbeams on...but that will take some electrical work...are you up for it? Also....if anything goes wrong down the road with your wiring or headlights, Ford will laugh you right out of the dealership for warranty work. IMO...send your current oem headlights to a place to retrofit BI Xenon HIDs into them...get it done the right way.
Ok, so basically everytime you need to flash your highbeams, you will ignite the gas, and then shut it off? So the high bemas never have time to warm up to their full running temp? This is why you go with Bi Xenon HId's...b/c the smae bulb stays on, and its jsut a cut off plate that moves.
