LED highbeam in dual beam projector set up?
Old 02-12-2011, 05:28 PM
murderout's Avatar
I was looking at these headlights but wondering if you could use an LED style H1 bulb in the high beam (as opposed to the halogen H1 that comes equipped) to match 6000k HID headlights in the projector low beam. Since HID's have to warm up you cannot really use them for separate high beams since they wouldn't have the responsiveness of a halogen or LED bulb, but would the LED be bright enough for high beam use? I know LEDs are brighter than halogen everywhere else so it seems logical.
Old 02-12-2011, 07:14 PM
Timelessr1's Avatar
Two problems with your theory.... Those lights projectors were not made to house HID's...just halogen bulbs. secondly, the way our lights work, is when you put the high beams on, the low beams shut off. This would not be good for the set up your talking about, b/c if you flash your highs, the HID's will shut off, and then have to come back on again after the highs are off...constantly doing this will dramaticly shorten the HID's life. Thats why ppl go with a BI Xenon HID set up, so the same bulb always stays on.
Old 02-12-2011, 07:25 PM
MGDfan's Avatar
Originally Posted by Timelessr1
Two problems with your theory.... Those lights projectors were not made to house HID's...just halogen bulbs. secondly, the way our lights work, is when you put the high beams on, the low beams shut off. This would not be good for the set up your talking about, b/c if you flash your highs, the HID's will shut off, and then have to come back on again after the highs are off...constantly doing this will dramaticly shorten the HID's life. Thats why ppl go with a BI Xenon HID srt up, so the same bulb always stays on.
Right on.
Plus - by now, most everyone knows we have a dedicated forum for lighting-related discussions.
More folks will see it - and in this case, more folks will pile on.
MGD
PS - those look ricey - sorry :o
Old 02-12-2011, 07:37 PM
And Led's don't put out enough light
Old 02-12-2011, 08:12 PM
camopaint0707's Avatar
Well I don't think they look ricey at all. But HID's in the low beams in there should be fine. Also LED's aren't going to put out the same light like a halogen bulb would. Although if you have HID low beams the halogen high beams probably wouldn't be much of a difference.
Old 02-12-2011, 10:31 PM
Raptor05121's Avatar
Replacement LED bulbs do not have the same luminous efficacy as halogens or HIDs as well. There are a few car makers with LED headlamps (Audi, Cadillac, etc) but they are a single 30W diode with a HUGE heat sink.
tl;dr- no. Keep halogens in that light
Old 02-13-2011, 02:20 PM
Lusso's Avatar
I tried replacing stock headlight bulbs with LED(18 SMD). But the light output was VERY poor, so I switched back to halogen. So I don't think using LED for highbeams is a good idea. Those LEDs are only good for color matching foglights to HID headlights.
Old 02-13-2011, 03:48 PM
You cannot put an LED or HID lighting system in a halogen setup and expect greater results. Its like taking your trailer off your F-150 and putting it on your Civic hoping you'll get better gas mileage while towing.
All three light systems have different "needs". None of them are interchangeable and the stores that sell these 9006 and 9005 LED bulbs clearly state they are for cosmetics only, not to be used for lighting purposes.
Old 02-13-2011, 08:01 PM
you can put HID's into projectors though
Old 02-13-2011, 09:22 PM
murderout's Avatar
If these Recon projectors aren't made to work with HIDs where might I find something that would?
Old 02-13-2011, 10:18 PM
yes but again, they aren't made for that unless you are referring to OEM xenon projectors.
you'd have to buy OEM xenon projector and retrofit them into your headlights
Old 02-14-2011, 07:48 AM
Timelessr1's Avatar
This is an awesome website/forum for HID information, and retrofits and projectors
http://www.hidplanet.com/forums/forum.php
Also these are perfect posts right up your alley :-) Maybe some other ppl might learn a thing or two also....
http://www.hidplanet.com/forums/show...hese-just-junk
http://www.hidplanet.com/forums/show...ood-projectors!!!
Old 02-14-2011, 04:14 PM
BL4CK0UT's Avatar
I am running these headlights with HID's in them, they say specifically on the housing that its not made for HID's but I dont see why not? They've been working for 4 months just fine with me.
Old 02-14-2011, 04:56 PM
Timelessr1's Avatar
what happens when you put on your high beams? Does your low beams (HIDs) go off? How long do you think that will hold up? just because you could...doesnt mean you should......
Old 02-15-2011, 11:00 AM
murderout's Avatar
is there not a way to make the projector stay on all the time?
Quick Reply: LED highbeam in dual beam projector set up?
